Question
Discussion in 'AMD Processors' started by Cataulin, May 4, 2015.
  1. Cataulin
    Cataulin [H]ard|Gawd
    1,089
    Nov 22, 2010
    Hi guys,
    Im new to AMD cpu's and I had a quick question about their iGPU line(7850k mainly). Say I use it with a GPU thats not compatible. does the igpu become regular cores that increases to whatever the igpu has? like going from 4 cores to 8?
  2. drescherjm
    drescherjm [H]ardForum Junkie
    14,568
    Nov 19, 2008
    It does not really work that way.
  3. Cataulin
    1,089
    Nov 22, 2010
    Thanks.
  4. durquavian
    durquavian Gawd
    757
    Dec 13, 2014
    With a dGPU only two options: 1. It isn't used at all. 2. You run it in CF if it is compatible with the dGPU.
    There is the hypothetical 3rd that it gets used for FPU calc like what HSA is attempting, but at the current moment that is not yet possible.
  5. Cataulin
    1,089
    Nov 22, 2010
    Sorry for all the questions but what/who is HSA? is this some forth coming portion of 10 that would use the igpu as a regular cpu core?
  6. MrCaffeineX
    MrCaffeineX [H]ard|Gawd
    1,436
    Aug 22, 2011
    http://en.wikipedia.org/wiki/Heterogeneous_System_Architecture
    It is something AMD is working toward where some of the iGPU resources can be used to assist with processing tasks to either reduce the burden on the CPU or to increase the overall performance of an APU or as durquavian mentioned, to handle some of the work that would normally be done by the dGPU to free up its resources for another task.
  7. Cataulin
    1,089
    Nov 22, 2010
    Thanks. I've not been up to snuff in my tech talk lately. I appreciate the link.
  8. Lunas
    Lunas [H]ardForum Junkie
    9,854
    Jul 22, 2001
    The cpu portion of the 7850k is no slouch it does not preform all that much lower than a fx 6300 hex core cpu. And the igpu is not a super weak one it can do most current gen games rather well.
    Amd wants the igpu to be available to run as a sort of coprocessor. It won't crossfire with anything over a r7 250 with ddr3 but if you are sticking a r9 or a ti 750 or better in any of those cards out preform the dual gpu mode with the r7.
