Okay, well, we just upgraded to ATT U-Verse from TWC at my apartment and they specifically told me I couldn't used my old wrt54g with tomato I've been using for QoS, bandwidth monitoring, etc. They told me I wasn't allowed to have *any* router behind the 2wire. The model of 2wire they gave us is the 3800HGV-B. They also gave us an 8 port gigabit belkin switch.
I really, really (I can't stress this enough) despise the 2wire router they gave us. I'm going to be getting a wireless N router soon that can be flashed with dd-wrt or tomato (I've used both, either work for my needs).
Is there a way to hook a router up behind this 2wire router that I can use to monitor all traffic, distribute IPs to my clients, create custom rules, QoS, etc? I would prefer the 2wire just to act as a passive modem, if that were possible.
They also fed me some BS (I assume it's bs) about changing the settings inside the 2wire, I might brick it. Sounds like a terrible firmware to me, adjust a setting that is available from the homepage and you end up bricking their router.
I'm just looking for advice. Currently I have 2 computers off of the 2wire, and then 6 machines off of the switch. I'd prefer to have just a router connected to the 2wire, then everything connected from there. Is that possible with these?
Thanks...sorry for rambling, any advice is appreciated.
