I just received an AMD Athlon 700 on an Asus K7M mounted inside, what looks like, an older Antec case with 2 80mm case fans.
The CPU has a stock HSF on it. The fan is loud as heck & I was wondering if I can run it without the fan or is heat an issue with this processor?
It's a very large heat sink & the fan is very small.
I won't overclock this & it will be used primarily for my kids (non-graphic intensive) games and word processing/browsing.
Thanks!
Thanks!
