I recently made a new build with an i7 w/ venomous X & push-pull fans with a 5870 in a ATCS 840 case. At 4Ghz stable, it seems to idle at low 40s and in Prime/Linx at 69-70, but this is with HT off and in a relatively cool room. With HT on Linx gets to high 70s
When the rig was being built and the case was open, the temps were much, much better so I think the case airflow needs improving (rather than reseating the heatsink - is this right?). I would rather not deck the case out with too many fans so as to maintain the quietness and keep down on expense!
Should I add two fans infront of the HDD case, or add an intake fan on the bottom of the case? Also, is it worth adding the external videocard duct box at the end or not to keep GPU temps down? Thanks.
