question about this tube res for a D5?
Discussion in 'Water Cooling' started by newls1, Oct 8, 2018.
  1. newls1
    newls1 2[H]4U
    3,996
    Sep 8, 2003
  2. VanGoghComplex
    VanGoghComplex [H]ard|Gawd
    1,631
    Apr 5, 2016
    Yep, add your own D5 and it becomes a res/pump combo.
    Can't speak to Alphacool's reservoirs on quality; never owned one. XSPC makes a res like that called the Photon, and it's great - it also comes is a 170mm version if you need something smaller. I've got a 270mm XSPC Photon D5 res I might be persuaded to part with cheap, PM if interested! =)
  3. newls1
    newls1 2[H]4U
    3,996
    Sep 8, 2003
    i need 2 res's and 200mm or bigger preferred
  4. newls1
    newls1 2[H]4U
    3,996
    Sep 8, 2003
    with the way the water flows through the base of this res, how bad do you think the restriction might be?
  5. VanGoghComplex
    1,631
    Apr 5, 2016
    Hm. I've got one, and it won't match a second one you could buy. You probably wouldn't want mismatched brackets.
  6. VanGoghComplex
    1,631
    Apr 5, 2016
    Probably not enough to make a D5 flinch. =)
