mrmylanman
- Jul 13, 2008
Is there any information out on this yet?
I know it's just a rebranded OEM water cooling block that they use on the Dells and HPs and stuff, I was sorta thinking about using it on my i7 since my Silverstone does not really have the room at all for a proper water cooling setup (and my Coolermaster V8 kinda left some to be desired). At about $80, it costs around the same as a TRUE would, when you consider the fan is not normally included. Would this thing be able to cool down an i7? I keep it overclocked at 3.6GHz, so it's not super high or anything. I probably wouldn't go that much higher than that (if at all).
Mainly looking to reduce noise, as well as maybe draw the temps down some (which like I said aren't that bad anyway).
