rhansen5_99
- Nov 12, 2001
I have a TYAN S2912G2NR Dual 1207(F) here: http://www.newegg.com/Product/Product.aspx?Item=N82E16813151070
That requires heat sinks with 4.1" mounting pitch. I see a dynatron with 4.1 pitch here: http://www.newegg.com/Product/Product.aspx?Item=N82E16835114059
The question I have is are there any other coolers such as zalman's that are able to fit this mounting configuration, basically I want something quiet, cheaper than $35/each, that I can use to cool my dual core opterons.
Thanks
Thanks
