So I am considering installing some Ethernet jacks around the house and I had a question about the wire needed. After reading around it says I might have to use CM rated cable or better for in wall installations which is fine except for the fact I can only find that type in 1000 foot spools (I only need about 100 feet).
Do I need the CM or better rated cable? If so, any ideas as to where I can get two 50 foot cables without having to buy the spools?
