erehwon6811
- Aug 5, 2004
I have been wanting to make a dual boot machine for a while now. I spent the last several days backing everything up and reformated the entire thing. My question is how should I partition it and what file system should I use. I have a 40 and an 80 gig hard drive. I've heard that linux has some issues with the NTFS file system. I was wanting to know if linux can run on NTFS or can NTFS and a FAT partition can exist on the same disk? I'm planing on installing Fedora linux. My school uses redhat on some of their computers and I thought I would start of learning something close.
My plan so far:
1st disk
20 gig Windows system partition
20 gig LInux system partition
2nd disk
40 gig Games & apps part (need atleast 20 gig since UT2k4 and HL2 going on)
20 some gigs for Data
My plan so far:
1st disk
2nd disk
