Question about buying a Nexus 6
cukoodukoo
Are the 64gb versions of Nexus 6 on Google store and Motorola website identical?I am interested in the white version which is only available at Motorola .
I came across this article which states that if you are on verizon your only go is Google store version.
TheHobbyist
Hugs Hard Johnnies [H]ard
They are identical. Unless you purchase the nexus 6 directly from verizon though, the phone will show up as "NON Verizon Nexus 6" on your account though.
cukoodukoo
I read online that verizon is not honoring any discounts if we buy a Non verizon Nexus 6.I spoke to the verizon rep and was told that all discounts would continue .:confused::confused:
ComputerBox34
You get the same discounts whether you have a Verizon N6 or Non-Verizon N6.
Buying through motorola is perfectly safe.
entropism
Buying through Google gives MUCH better customer support if something goes wrong though.
TheHobbyist
There were issues early on with non verizon nexus 6 and discounts, but they have been sorted.
