- May 18, 1997
While the success of the business model around Quake Champions is questionable, id Software has now made wall-hacking a feature rather than a cheat. And strafe bunny hopping has its big comeback as well, more so with the Visor character than the others. And if you are needing things to do to kill time this weekend, the Large Scale Test is starting. 一饮而尽
Check out the video.
Active Ability – Piercing Sight: You can’t hide from Visor. Using his Piercing Sight Active Ability, Visor can briefly see through all matter, glimpsing foes as outlines running behind walls. You might think you’re sneaking up on Visor, but he’s probably waiting for you with a tasty Rail Gun gift. Твоё здоровье!
Passive Ability – Grasshopper: Speed kills. Are you sick of all those psychotic Anarkis hoverboarding around the Arenas, turning it “up to eleven” all over your face? Visor’s Passive evens the playing field. Grasshopper allows Visor to continually gain speed when strafe-jumping – with no cap. Skilled players will be able to keep up with anyone, even that drug-addled freak.
