lens pirate
- Jan 1, 2009
I have been struggling to get my PC built with top of the line parts to overclock to what everybody else seemed to be getting while keeping the tempuratures in a reasonable range.
Let me say that my CPU WILL run at 4GHZ and will do so at crazy high voltages and heat.
I ran some test were the CPU was still runing fine at over 90C when I stopped the test out of fear.
I tried every thing I could think of and read about. I finally settled in at 3.6GHz with the CPU voltage at 1.275. This allowed me to be all night stable running Linx and Prime95.
If I raised the CPU speed at all with out raiseing voltage from here it would fail every time.
if I dropped the voltage any from here it would fail everytime. It seemed I havd found my sweet spot in terms of Temp/voltage/Clockspeed ratio. I was sort of disappointed.
Then I read a thread were some guy mentions in passing that he was limited by QPI voltage!
As it turns out my QPI voltage which was set to auto was a limting factor!!!!!!!! Woot. I raised my set my QPI voltage to 1.39 and WHAM! all of a sudden
3.8 ghz at a cpu voltage of 1.268 was fine. This lets me run my memory at 1600 hundred and 1.64 volts. Temps stay perfect not going over 74c on the CPU under multiple passes with LINX or IBT and prime 95. Best of all this is all I have tested to so far. There may be more room on the CPU voltage. Which means there may be more room in the Overclock.
Its possible I may have a 4 GHZ cool running box yet! The moral of the story is don't give up...test test test!!!!
Man the I7 processors are amazing and will over clock like crazy but damn... It sure is more complicated than other chipsets of the past.
