So I have decided to get a QNIX QX2710. Sounds perfect, 1440p, 60Hz, overclockable, inexpensive. I dont plan on overclocking it though, because at 1440p, a GTX 970 can usually hover around 60fps anyways, so it's not worth overclocking it and getting the disadvantages of OC'ing it.
On Newegg, there are three types of this monitor: Just the QNIX QX2710 ($360), a Perfect Pixel (no dead pixels) version of the QNIX QX2710($420), and a QNIX QX2710 Evolution II($310). The only difference I see here between the regular one and the evolution ii is that the Evolution is the cheapest, claims to be overclockable, has a 2ms shorter response time, and is an AHVA panel instead of a PLS panel. As far as I have researched, AHVA and PLS panels are basically the same. What is the difference between the panel types? What are the real differences in these three monitors, that you claim? Which should I get?
I am leaning towards the Evolution II because it says it has a 6ms response time, as opposed to the 8ms time of the regular QX2710, says it is "overclockable" and is the cheapest. I probably wont mind if there are one or two dead pixels on whichever monitor since they will hopefully be so small that I cant even tell.
So yeah, what are the differences in these monitors? They seem so closely matched? I cant find any info from the manufacturer or Newegg, Amazon, Ebay about ports, other than they all have DVI-D, so any help on that aspect, guys? Which, out of the three, should I get?
Please help. Any info, help, etc. is greatly appreciated. Thank you in advance!
