So I just installed a Q9650 a few min ago and as the title says, cores 0 and 1 are idling around 34C and cores 2 and 3 are idling at 26C according to Coretemp. I cleaned the water block, spread an even line of thermal paste (TX-2) across the CPU like i've done a million times and then put the waterblock back on. I ran a quick small fft run on prime95 and under load cores 0 and 1 showed 45C while 2 and 3 showed 39C. It's kind of bizarre...should I tweak the 2 screws on the core 0,1 side of the waterblock or what? Though I'm pretty sure I tightened all the screws about the same amount.
I just wanted to check with you guys before I stress out about it.
