Just put together a Gigabyte X48-DQ6 with a 9450 with a lapped TRUE, 8GB of G.Skill 1066MHz DDR2. MemTest86+ was happy so off to Vista 64 install. Installed Everest Ultimate 4.5 and idle, I see about 32C with core temps of 50, 50, 42 and 42. Prime 95 load hits CPU temp of about 42 and core temps of 60, 58, 52, 53 or thereabouts. Room temp is 83F. Do these core temps seem out of whack? I used OCX's Freeze Extreme rather than my usual AS5. The CPU temp doesn't seem too bad at load but I'm not sure where that's read vs the cores. Think a TRUE reapply/reseat is in order? This is in an older Stacker case with plenty of air flow and a Rexflo 120mm PWM fan on the TRUE.
