So i just picked up a cheap quad, q8200, and finally got around to setting up a push/pull setup on my true. Anyway i upped the volts by 0.125 changed fsb to 428 and its stable straight away @ 3ghz, idles @ 27c.
It seems 3 of the sensors are stuck(core 2,3,4) at a specific temp unless it goes higher. Core 1 - 27c, core 2 - 32c, core 3 - 38c, core 4 - 38c, when i run cryostasis tech demo max details 1680x1050 all the cores get to 38c.
I'm pretty happy with the results so far, time to keep pushing and i will update you.
specs:
Q8200
Asus p5k3 deluxe
Corsair xms3 DDR3 1333 @ 1427
Silverstone strider 600w
specs:
Q8200
Asus p5k3 deluxe
