ChronoReverse
- Feb 21, 2005
Hmm, you didn't record my reply from xtremesystems.
G0 1.3125
G0 1.3125
The VID changes after you OC, right?
Weird in that case. CoreTemp's acting a little strange after I started OC'ing.
It is now displaying my VID as 1.300 and always displays my FSB as 50 mhz more.
Oh well..
Overclock results? Yes, I'm following you...lol
Q6600 G0
L720B023
VID - 1.275
Hehe, doing so as we speak. I'm on the laptop at the moment just watching prime95.
But yeah, im going with the old VID o_o.. lol, no idea why the VID changed after i started playing with the BIOS..
Anyway, I am idling at 34 deg celcius ~ (temps taken from CoreTemp & Abit's uGuru) and load prime95 @ 54 deg celcius.
Though, in CoreTemp.. what is the temp we take? Core#0 ? Core#1 ? Core #2 ? Core #3 ? or take all of them and average?
Anyway running at 425 x 8 for 3.4 Ghz so far @ 1.4 volts, seems stable so far.
Gonna shoot for 3.6Ghz as my end result methinks.
What are you running?
stock.
Waiting on a scythe ninja plus
This is my first time ever OC'ing so I'll get the retarded question out of the way:
How long do I run prime95 for to know that the system is stable?
All the instances of past instabilities due to lack of voltage @ cpu or memory occured in like the first 5 mins.
Is the best test to leave it running all night?
Again, I'm planning to update the thread with all the new results soon...
for all the people who responded w/ a g0 1.2750 chip... how high have you o/c'ed it and @ what vcore? What minimum vcore can you run 9x333 at?
Guys be aware that if Enhanced C1E or SpeedStep kicks in you will see the idle VID setting and not the running VID setting (which would explain the rather low values some have, see post #48 as that shows 6x multiplyer, throttled and idle VID setting (sorry Gaiden133 but yours was the only post to show it graphically)). You can tell which you are seeing by also running CPUz and checking the multiplyer. If it says 6x then its throttled (unless you are running insain FSB speeds).
Right now I'm at 9x334, still haven't bumped the voltage up from 1.2750 (which is the lowest possible setting in uguru, presumably because it read the VID). Haven't hit even an hour of stressing yet (Prime95), but I ran it for 4 hrs at 9x320 with no problems, and I think it's safe to assume it will be stable at this setting. I'll update if it isn't.
Temperatures boggle me though, because today it's not quite getting as hot as it was last night at 320 (55C max in uguru, 62 in coretemp0.95). Right now it seems to be a couple degrees lower in both apps despite being clocked higher and my room feeling the same.
50 replies so far for B3 stepping Q6600s:
2 people had a VID of 1.1625V --- 4%
1 person had a VID of 1.2125V --- 2%
2 people had a VID of 1.2500V --- 4%
2 people had a VID of 1.2625V --- 4%
7 people had a VID of 1.2750V -- 14%
8 people had a VID of 1.2875V -- 16%
6 people had a VID of 1.3000V -- 12%
1 person had a VID of 1.3100V --- 2%
8 people had a VID of 1.3125V -- 16%
13 people had a VID of 1.3250V - 26%
14% < 1.275v
86% >= 1.275v
weighted AVERAGE = 1.2925
32 replies so far for G0 stepping Q6600s:
1 person had a VID of 1.1520V -- 3%
2 people had a VID of 1.1625V -- 6%
1 person had a VID of 1.2125V -- 3%
1 person had a VID of 1.2250V -- 3%
2 people had a VID of 1.2375V -- 6%
4 people had a VID of 1.2500V - 12%
6 people had a VID of 1.2625V - 19%
3 people had a VID of 1.2750V -- 9%
1 person had a VID of 1.2850V -- 3%
4 people had a VID of 1.2875V - 13%
5 people had a VID of 1.3000V - 16%
2 people had a VID of 1.3125V --- 6%
53% have <1.275v
47% have >= 1.275v
weighted AVERAGE = 1.225
B3 VID:1.1625v
SL9UM Pack Date: 07/11/07
About to add a second fan to my Ninja B and then im going to see how high I can clock it.
Since coretemp .95 doesn't work on Vista 64, are you missing all of those that are on that version of Vista? Is there another way of getting VID?
G0@cloudfan: is that a g0 or a b3?
