Had this baby running @ 3.6 on air for awhile now and it crapped out yesterday. I was able to resuscitate the box by bringing all the settings back to stock and have no desire to mess with it anymore with LGA2011 around the corner. I was going to jump on the LGA2011 bandwagon anyway, so this is my excuse to do it sooner. Going to order everything this week, then a mobo and cpu when released.
The biggest concerns are case & PSU -- I will be using it for video capture via my black magic intensity card (so it is close to the camera, so no open sides to the case with lights showing through or loud noise).
I did fine capturing to a raid array on the Q6600 with the Intel Raid controller built on to the Asus deluxe board, but may want to step it up in this build to a separate controller card, if that's advised.
I have a GTX 470 card that can be reused, but may not want to if there is a better card that runs cooler, quieter, and is Premier Pro CS5 Mercury Playback compatible.
CPU cooling can either be the best you can get on air, or simple liquid (like an H100). Nothing complex that requires case mods, so a case that can handle stock anything would be great, and big enough to work in.
So, I need: case, psu, ram, video card (if advised), raid controller card (if advised), cooling, SSD, hard drives.
I have an external QNAP NAS for backup, so the internal drives will be RAID0
And for good measure:
Live video capture, rendering, photoshop, web browsing, asp/database programming, 4 VMWare windows running, No gaming.
Up to 3K for everything but the mobo & cpu
Los Angeles CA USA
Case, Fans (if not supplied with the case or upgrades are recommended), PSU, CPU Cooling, Ram (preferably 32G at least), maybe video card, maybe raid card, SSD for OS and programs, drives for raid.
2 Dell U2410's, maybe the GTX 470
6) Will you be overclocking?
Yes, but not to extremes. machine needs to run 24/7.
2 24" 1920x1200
Within 7 days for everything but the mobo & CPU. Will by those when LGA2011 is released. Can wait till LGA2011 on some of the components if better stuff is going to be released about the same time LGA2011 arrives.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
TBD, unless anyone knows now based on previews.So far, the ROG IV looks to be the best.
Yes, Windows 7 64bit
Los Angeles CA USA
2 24" 1920x1200
