Vista 64 just released a update not too long ago that makes it so you cannot disable forced driver signing when you startup, so he will not be able to monitor his temps using CoreTemp.
What kind of temps were you getting fully loaded @ 4.1?
Good to know. Can any one please specify the correct setting for Prime95
There is no common app that loads a quaddie up like P95/Orthos. The flip side of that is that if an overclock can survive P95, it WILL survive absolutely everything else. Load testing is about finding the worst possible situation after all.
So you don't consider Folding valid?During the single core era it made sense to be 100% Prime95 stable. No other real world application loads a single core the way Prime does so if you were Prime stable you were good to go.
With a dual core processor, being 100% Prime stable for a mega hour run isn't as important and with a Quad core it becomes even less important. The reason is that there are no real world applications that will load all 4 cores simultaneously the way Prime does and create as much heat as Prime does. Software development is not keeping pace with hardware development.
New games that are multi-threaded are not loading all 4 cores anything like Prime does. Supreme Commander is a good example. X-Bit labs showed that overclocking a Quad by 50% from 2400 MHz to 3600 MHz only resulted in a 3% increase in frame rates. That's a good sign that all four cores are not being fully utilized, even in a multi-threaded game. A Quad will barely be above an idle while playing the other 99.9% of single threaded games that are presently available.
Here's a good example with my dual core E6400 when I was feeding it lots of voltage and plenty of MHz with the Intel OEM heatsink and fan:
A temp of 73C was right on the edge of randomly re-booting during a long Orthos run but when running Need for Speed at the same specs, I had a pile of temperature head room. My computer was rock solid stable for the games I play as well as anything else I threw at it.
Being Prime stable on a Quad is sort of like hooking a semi-trailer full of bricks to the back of your Vette and heading up the highest mountain as fast as you can go to see if it will over heat or not. Brick hauling is as overkill for testing a car as being 86 hours Prime stable on a Quad. An hour plus of Prime on a Quad is plenty stable enough for any real world tasks you'll presently encounter.
You put alot of trust into P95, I give it a hit or miss, considering the results i've seen from P95 on perfectly stable machines, even stock machines, that would fail P95, but once you update to a different soundcard driver or video driver, the problem went away? Kind of odd that it would raise a red flag in regards to a software driver?
To date, I've never seen P95 fail due to software.
Just to try Prime95 i had to raise my VCORE above 1.65 or upto 1.6875. I think that was really stupid of me to just get verified that my CPU is stable, i put my CPU at risk. Here is a kick, now i am not trying Prime95 and in real world day to day use since yesterday i dropped my Vcore back to 1.5 @ 4.1ghz is running perfectly fine. I played Games, like BioShock, C&C3, both Games for 1 hour at least. Ran Multiple Operating systems in Virtual PC, Watched HDTV broadcasting on PC @ 1080i, SuperPi32M, and it all went fine and i thought why in the hell i need to run Prim95 for 4 hours or so. Why ?
Maybe because all those programs use like 1 core You'll always be living in doubt, maybe this next program will crap my pc. You can never know when your pc is going to reboot or crash. For me, under 12 hours orthos isn't stable. And even if it manages the 12 hours, I still might drop down my oc just a little to be 100% sure. Running crazy ass oc's 24/7 isn't worth it at all. You lose stability and gain, well, practically nothing. Or are you telling me you'll actually see some difference between 4.1 GHz and, say, 3.5, which will run ALOT cooler and with alot less voltage. Much healthier for the cpu itself, and more practical.
Klinky: My temperatures are under 50C, how can i burn it with only 1.5V
Also i notices in the last few days, since i get this CPU @ 4.1, my PSU 's fan is spinning at full speed, and throwing really HOT air from the back.
Congrats highest OC I know of with the Quad!
Thanx man, i really appreciate that. I see TurtleTrax got it stable @ 4Ghz with Prime95 for more than 4hrs.
That is awesome man, how you did not, wanna share some info of your setting. How did you manage 4 hrs of Prime95 ?
Wow, PC are using 500 Watts means $400 / per for Electric usage at least. These companies need to come up with lowe Power CPU like 1 W cpu from VIA.
