Jensen's "It just works" refers to the lighting/reflections, a statement aimed at game dev's who normally have to do all kinds of tricks to get reflections to work in rasterized games... and even then, it doesn't work 100% right. A light source coming from a player can be hidden behind the wall, but still be reflected on the floor on the opposite side of the wall... giving away your position. That doesn't happen with raytracing. Example: star wars battlefront, light saber wielding hero is waiting near a door, and you can see the saber glow on this side of the wall.. crap like that "just works" correctly when raytraced, and the light from the lightsaber isn't visible on the floor. (Jensen should have much better articulated what he meant with the whole 'It Just Works' statement.)
I guess you didn't watch the video...it runs just fine.
Admittedly, we didn't see any sections with a huge amount of action going on, so who knows later in the game.
Dude, I was making a joke...
Is this RTX hardware specific, or is there anything preventing an AMD driver from implementing this? I was under the impression that the Ray-Tracing for Vulkan was going to be platform agnostic, so it would be dissappointing if that was not the case.ok then. Specifically mentions the NV extensions under NVIDIA Corporation.
https://www.khronos.org/registry/vulkan/
- NV Extensions (NVIDIA Corporation)
- VK_NV_clip_space_w_scaling
- VK_NV_compute_shader_derivatives
- VK_NV_corner_sampled_image
- VK_NV_dedicated_allocation
- VK_NV_device_diagnostic_checkpoints
- VK_NV_external_memory
- VK_NV_external_memory_capabilities
- VK_NV_external_memory_win32
- VK_NV_fill_rectangle
- VK_NV_fragment_coverage_to_color
- VK_NV_fragment_shader_barycentric
- VK_NV_framebuffer_mixed_samples
- VK_NV_geometry_shader_passthrough
- VK_NV_glsl_shader
- VK_NV_mesh_shader
- VK_NV_ray_tracing
- VK_NV_representative_fragment_test
- VK_NV_sample_mask_override_coverage
- VK_NV_scissor_exclusive
- VK_NV_shader_image_footprint
- VK_NV_shader_subgroup_partitioned
- VK_NV_shading_rate_image
- VK_NV_viewport_array2
- VK_NV_viewport_swizzle
- VK_NV_win32_keyed_mutex
- NVX Extensions (NVIDIA Corporation)
- VK_NVX_device_generated_commands
- VK_NVX_multiview_per_view_attributes
RTX Space Invaders was the first demo. Quake 2 is the next logical progression. At this rate we can expect fully raytraced games of today released in 20 years.Looks pretty sweet. Almost makes me want to fire it back up. Honestly, it should be included in the Nvidia games bundle. Lol... "It just works". Finally, something actually "just works". Perhaps the next step is to create Ray Traced Space Invaders
Good to see a 20 year old game can run at playable FPS with ray tracing enabled.
Well, I think it looks pretty sweet. Frankly, actual ray-tracing is going to be huge.
The first part of this demo looked amazing, especially dark areas - wow. But there's more to be desired overall. We need some kind of deeper level light source analysis tools so that awesome old games can look amazing again. Remember, lighting is the most important part. If that looks right, everything else is secondary
That was very cool, I remember it well. Give this RT thing 2 mote generations and it will be awesome. Thanks to those who are willing to bankroll it, I'm not, but I do appreciate others doing it!It's kind of a spiritual successor to the original quake ray tracing experiment ages ago that was sub 1fps on every computer at the time.
Not to go off topic but it was 9 years between Quake 2 and Crysis... and it's been 13 years since Crysis...
I miss the days when every year there were dramatic leaps in games technology and firing up a 2 year old game was like "whoa this looks ancient".
You can run quake and quake 2 at full resolutions of todays' monitors.. no reason to play in 640x480, and that raytraced demo is most definitely not 640x480...
The lightsaber jedi example is a good concept too. I can see your lightsaber glowing off the wall, come out from that corner. No you can't see me, I'm rasterized...
Honestly I think it looked much better back in the good old days when I had a 3Dfx card and their GLide support.
But then I got a Matrox G400 and that to this day produced what I still consider to be the best-looking graphics output of any card that I've ever been able to use. When Unreal (and I do mean the original Unreal which just celebrated its 20th anniversary last year) was played on a G400, good Lord, it was like an orgasm for your eyes.
I can appreciate the amount of time and effort that has been put into producing these revised versions of the old classic games, but as far as this one is concerned I don't think that ray tracing is going to do anything for it.
Nope, they say they require an RTX GPU,They say they use the Vulkan API, so it shouldn't require an RTX card per se. Probably won't perform well right now on AMD hardware, but with the right support, Vega 2 might do it alright.
Vulkan, new accelerated raytracing hardware, 2080Ti.Q2VKPT is implemented in the Vulkan API to be able to use the new hardware-accelerated raytracing features that were made available earlier this year. Thanks to these, the game can actually come close to 60 FPS (2560x1440, RTX2080Ti),
It ran with crap fps, and without a denoising filter, and without textures too. BIG difference.They have had the Raytracing mod going for about 2+ years now (originally called Pathtracing), and it was designed to run on both AMD and Nvidia. Yes, it will run better on Nvidia RTX series cards, but the original project was designed to run on both. So Jardows is correct. The calls you listed are for Nvidia only.
Had the exact same setup plus a Rainbow Runner analog capture card Mystique add-on. Quite the setup back in the day. I too gambled on PowerVR as it only seemed logical at the time that tile based rendering would be the future.For me it was a 4MB Mystique 220 and a PowerVR M3D card. Unreal/Quake 2 etc. looked fantastic.
Someone should do this with Doom 3, so we can see more dynamic lights and bounce light (and AI-upres those textures while you're at it)
I agree. Lights and shadows in Doom3 were not very good (well they were at the time, but not anymore).Even with all the best mods, it still looks kind of flat. I'd love to see RTX implemented in this game.Oh hell yeah! If there is a single game that would benefit the most by Raytracing it would be Doom 3. I mean, its rudimentary dynamic lighting and self-shadowing was kinda ground breaking and tried to give an impression of real lights and shadows, but it is also what made the game unplayable without the duct tape mod (there either was light or none at all, everything else was covered in pitch black shadow). I believe having an actual raytracing with real lights that bounce from walls and illuminate surroundings might make the game playable without mods while still looking dark and scary, shadows are getting casted where they should be and so on.
I was shocked to see a M3D card sell on Ebay this week for £155 ($200)!!
I threw mine in the trash or gave it away many years ago.
I recently played through it vanilla and almost never used the flashlight... maybe just a few times in the beginning level - maybe that's how far most people got before declaring the entire game was like that? some later levels were really really stunning and in general better litunplayable without the duct tape mod
for me with Doom 3, I'd love a soft diffuse light emitting omnidirectionally from the armor... would provide better visibility than something like a flashlight which would produce sharp shadows... and also it'd look more like original doom 1/2 how things get brighter as you approach them
as far as the ultimate game to utilize RTX... Euro Lighting Designer Simulator... take that dream gig with your favorite rock group or serious gig with an architect or fulfill your artsy fartsy at moma and other playgrounds/gallaries, whatever...
I sill have my M3D card. I don't know if it still works. Unreal, quake and Tomb Raider looked amazing on it.
I would definitely be the target market for that.Its really easy to go for the obvious jokes on this one. No one is buying a 1000 dollar card for quake 2 of course. Having said that.....
There has been a healthy market for HD remakes the last few years.
Ray traced remakes of some 20+ year old classics... might actually be pretty killer. In a couple years if main stream Navi, and perhaps Nvidia ampere and even Intel gpus feature tensor hardware. There may be a good market for ray traced versions of games like quake, unreal, system shock. thief and a ton of other 90s/2000s titles.
I know most [H] readers are likely north of 30... perhaps even 40+. lol But for a lot of younger gamers... they have never played some of those classics. I imagine the companies that own the rights to some of those titles might be looking at pretty good return on investments if they where to spend a bit of time re doing them. I guess the real question would be how many of those classes have nice neat well kept source around still. lol
With the way ray tracing is such a consumer of power and really just something optional. The smart thing to do would be to sell cards without raytracing and have it be able to be added with an add in card. If I could buy a 2080ti (or equal) without Ray tracing for say.. 600 bucks, then later if I wanted it add ray tracing for 400 later.. or even 150 later because it's an add in card. I would be all about it. As it stands doing it as one big Processing unit is taking away from the over all.
Maybe DirectX 12 can provide this option of adding ray tracing via an add in card ?
