serpretetsky
- Dec 24, 2008
I have 2 4-pin fan outputs from system. I need to either to limit the duty cycle to some max value, or to adjust the duty cycle to limit the tach to some max value. I don't care which.
The tach from each fan MUST come back to the 4-pin fan output from the system (I need the system to still be able to read the speed of each fan).
Cheap is good, i don't need any fancy interface, I don't need any LCD screen, Bare PCB ok, just need some way to limit to a specific duty cycle/tach speed (I'm guessing POT, but little switches/jumpers works too). Need options to limit speeds between 2000rpm to 6000rpm. Or options to limit duty cycles between 10% to 50%. Speed/duty cycle limit can be global for all attached fans.
I looked around briefly but I'm not sure how to tell what the controllers actually do with the individual signals (some look like they don't even bother using 4-pin outputs from the system and just use something like the ide hard drive 4pin molex simply for power) .
Do you guys know what options I have?
