Putting together a PC for a friend
Uncle Humjaba
Hi all,
Putting together a computer for a friend.
- Solid modeling, FEA and CFD work, plus daily things
About $1k. He has amazon prime, so while the links are to newegg, the purchase will probably be from Amazon
Greenville, SC
CPU, storage, ram, power supply, case, monitor, windows, mouse/keyboard
No parts reused
6) Will you be overclocking?
To extend life down the road
Want 1080p
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB3, Sata 6, onboard video is main for now (upgrade to GPU as needed)
No, buying Win8 64bit
Here is what we've got so far:
i7 4770k $174 Employee store
Motherboard
MSI Z87-G41 PC Mate LGA 1150 Intel HDMI SATA 6 Gb/s USB 3.0 $110
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130695
Memory
PNY XLR8 8GB 240-Pin DDR3 SDRAM 1600 (PC3 12800) $70
http://www.newegg.com/Product/Product.aspx?Item=N82E16820178654
Power Supply
EVGA 600 B 80 PLUS BRONZE Certified 600W $60 - $20mir
http://www.newegg.com/Product/Product.aspx?item=N82E16817438014
HHD
SSD - Samsung 840 EVO 2.5" 250GB SATA III $190
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147248
Internal - WD 1TB $90
http://www.newegg.com/Product/Product.aspx?Item=9SIA2W00ZD1577
Case
$40 - Tiger direct pick up
Monitor
ACER 23" $120
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009421
Windows 8 64-Bit $100
Keyboard
Dangman
Ninja Editor SuperMod
I would recommend this more reputable PSU:
$50 - Corsair CX500 500W PSU
As for the case, I recommend this more than likely better than Tigerdirect case:
$43 - NZXT Source 210 Elite Black ATX Case
