86 5.0L
- Nov 13, 2006
Ended up slipping and falling atop of my rad, sending bolts straight into the core. This is an older 20fpi design that I was using in a push/pull with GT15s. I see most rads are now 16fpi or lower, what do you guys think? should I try hunting down a similar replacement or what would you recommend?
cooling a 7700k plus a 1070(maybe a 1080)
