Id love to have my pump/ res visible from case window, and the only way to do it in my h440 is (apart from cutting side panel and using bigger glass and I don't want to bother with it) to use vertical pump holder and place the pump res at the top rear exhaust fan.
Will there be any drawback to the solution of having pump almost at the top of the loop?
