In the wake of the lackluster Fury X I'm dropping some coin on a 980 Ti SLI setup with a second custom loop.
Water Cooling availability is fairly sparse at the arse end of the world so I pretty much have no choice but to go for a full EKWB setup (although I'm not unhappy about that) I'm just stuck in terms of the type of pump and tubing to get.
Am I correct in assuming the best option pump wise is a DDC type pump (for higher static pressure vs high flow D5)? I'm looking at getting an EK-SBay Dual DDC for this loop.
Tubing wise, I have 1/2" ID tubing for the CPU but was looking at going to 3/8" ID for the second loop. I'm assuming flow will be highly restricted by the VGA blocks so the tubing diameter is less important.
Any thoughts would be greatly appreciated.
