Psu for Rtx 3090 and 10850K
mgty23
Hello lovely users.
PC:
10850K stock with Kraken X73 cooling AIO
2x16GB DDR4 RIPJAWS ( BLACK ) GSKILL 3200mhz XMP ( will be ON )
Aorus Z490 Pro Ax
Gigabyte Rtx 3090 Gaming Oc ( stock ) ( 2x8pins )
1ssd 2tb Crucial <Nvm P1>
And yeah thats all. Which psu will be enough and the best? Wanna solid psu for that build. Thank you
PS:
Was searching for Seasonic 1000W TX ULTRA TITANIUM but nowhere is on stock.
So maybe 850W? But not sure. Cpu is hungry also.
THank you for recommendations :) Cheers
dtnh
850 watt is minimum for a system like that.
RM850 Corsair is what I know a friend is using for a similar system. But not overlocked
kirbyrj
I think 850W would be enough unless you plan on adding a lot of extras later. I wouldn't go crazy looking for a Titanium PSU. A gold or platinum should be fine unless you plan on running it 24/7/365 for the entire life of the PSU (even then I'm not sure you would ever actually make up the difference in price in electricity savings).
mgty23
I was searching for 1000TX SEASONIC model but is out of stock everywhere
Dan_D
Extremely [H]
I have a similar configuration and I'm using a Seasonic Platinum 1200w PSU. That being said, I am overclocking everything and watercooling as well. I also have several physical hard drives in addition to the SSD's.
Spartacus09
Between general product availability, chinese new year, and mining?
getting anything above 1000w is going to be difficult, but 850+ ok, 1000+ is ideal
Niner21
I have a 10850K and a 3090 and I run a Seasonic 1000W gold. Best buy usually has them in stock. Amazon does as well for a high price though.
Dan_D
Extremely [H]
Microcenter has been hit and miss. That said, I think your right in that 850w units seem to be common enough.
MrAgmoore
I noticed that Seasonic Titaniums were sold out in Canada and USA back in Dec 2020 ( the 850 W & 1000 W ) but... I recently noticed on Newegg.com that you can ship a 1000 W from Hong Kong... ( they send two power cords, one for Honk Kong and one for the destination ).
https://www.newegg.com/p/1HU-0019-0...=seasonic_titanium-_-1HU-0019-002G6-_-Product
I live in Canada ( I always have to think about import taxes when shipping from the States ).
I've been doing a mishmash of manually trying to calculate power requirements ( like 150 Watts per PCI-e cable + 75 Watt from the PCI slot ) + CPU requirements + reviews + NVIDIA requirements + Toms Hardware chart ( Tom's is saying that 3090+ Intel HEDT = 1KW):
https://www.tomshardware.com/news/nvidias-rtx-3000-power-supply-requirements-PSU-shortage-2020#:~:text=For the Nvidia GeForce RTX,HEDT and AMD Threadripper platforms.
I emailed Seasonic on Newegg a week or so ago and asked them when we are getting Seasonic Titaniums in the 850W+ range and no reply. That's actually why I logged in - to find out if there was any information... because I see Seasonic Platinums go in and out of stock for the 850 W ( in Canada ) - I noticed they are back in stock today.
An APC UPS 1000 Watt is twice as expensive as a 850 Watt.
Are there rare earth metals used in the Titanium line? Why are they so hard to find?
mgty23
yeah but Seasonic Tx 850W Titanium Prime is on stock here in Poland but prize is crazy
MrAgmoore
If you live in Poland you can try and find a "good" rebadged Seasonic:
https://www.tomshardware.com/reviews/corsair-ax1000-80-plus-titanium,5966-6.html
Best Power Supplies 2021​
https://www.tomshardware.com/reviews/best-psus,4229.html
Yesterday Amazon.com had 7x Be Quiet! Dark Power Pro 12 1200 Watt power supplies but today they are all gone ( $700 CDN including the stupid import taxes, so I decided not to buy ). If you find something at a good price, it's best to buy it.
Dec 29 2020, when I found out that I couldn't even back order a Seasonic Titanium, I ended up buying a Fractal Design Ion+ 860p ( I bought it because I really liked the Fractal Design 7 case, so I was curious about the PSU ). $189 CDN for a Platinum power supply was crazy good. What is weird is that when the Ion+ 860p went out of stock, they erased it from the store, so you can't even see it on Newegg.ca ( which is weird ).
https://www.fractal-design.com/products/power-supplies/ion/ion-platinum-860w/black/
https://www.tomshardware.com/reviews/fractal-design-ion-860p-power-supply,6239.html
undertaker2k8
Another vote for the 850 RMX, powering my rig below.Get one soon because scalping may come to PSUs next...
mgty23
But if i order Seasonic Tx 850 Prime Titanium Plus it will be enough? This psu is only in stock.
MrAgmoore
Amazon Canada started taking pre-orders for: Seasonic Prime TX-850, 850W 80+ Titanium
In reviews, the PSUs run much higher than the rating on the box, with the premium lines running even higher.
Take a look at page 6: https://www.kitguru.net/components/...ic-prime-850w-titanium-power-supply-review/6/
"We managed to get the power supply to deliver 1098W before it would shut down, delivering around 152W more than rated specifications."
mgty23
So Seasonic Prime TX-850, 850W 80+ Titanium should be enough for that specs? I cant find anywhere here in Poland 1000W good psu.
akhoundog
So I'm running your gpu and cpu setup with the 10850 5.1 all core and the zotac 3090 flash to reduce power limits. im running 7 120mm case fans and 2 on the nh-d15. 3 HHDs and 3 SSDS.
My PSU is a corsair ax850 and while running various benchmarks my killawatt shows about 630 watts used... 400watts in most games and 90 at idle. Ive read about 30 series gpu having huge micro spikes of draw but the killawatt doesn't or cant show that.
mgty23
So if i order Seasonic Prime TX-850, 850W 80+ Titanium will be fine? But i dont see anywhere in Poland,1000W in stock.
mgty23
If i order that Seasonic Tx 850 Prime Titanium Plus it will be enough? This psu is only in stock.
I was searching for 1000W but nowhere is on stock,any model.
PS:
I must sold my Xbox Series X to get cash for PSU and SSD clear.png hehe . Anyway please answer to question about psu thank you.
Sky15
I went with a Phanteks RevoltX 1k PSU
Same set up as you, but AMD 5950x. Phanteks uses seasonic's internals so it's a quality unit.
NukeDukem
My Seasonic PRIME 850w was not enough when I pushed the 3090 to full +114% power. I had a couple system shutdowns while playing RDR2 and Horizon Zero Dawn.
After replacing the unit with an EVGA 1000w, I had no more issues. Theoretically the 850w should have been enough, but my personal experience said otherwise.
mgty23
Ok guys i ordered Seasonic Prime Titanium Tx-850 . Tommorow i will get it.
mgty23
Hey guys . I completed and bought all pc parts. Today psu and ssd arrived.
In monday my technician friend coming to plug all new parts pcclear.png. Cant wait to play Control hehe :)
Really greatful for your replies and help. Thank you. :)
vegeta535
PS:
I must sold my Xbox Series X to get cash for PSU and SSD View attachment 332379 hehe . Anyway please answer to question about psu thank you.
Yes it will be enough for your system. Even with OC room. I recently upgrade to a Seasonic 850w platinum gpu cause it was the only one I seen that had support for 5 pci-e/cpu 8 pins
