ok guys and girls. here we go. i have found a lot of information in varrious places on this subject.. so i will try to make this a place to get all of the info i have found so far. that way if you guys ever get the urge you know it can be done.
first..
http://forums.ps2dev.org/viewtopic.php?t=3140
this is where someone has coded an open source raw ir program for the psp...
also..
http://forums.ps2dev.org/viewtopic.php?p=26634#26634
someone has taken this raw ir source and made a phillips remote.
there are examples in the code on how to define the carrier signal and also how to modulate the pulse width...
and ..
http://www.xs4all.nl/~sbp/knowledge/ir/rc6.htm
here is a link with some commands and explanations of most ir home devices.. other are available else where.. and the rest can be scoped if we so desire..
if you need any of the files because links arent working or something i have them..
how i first got involved in all of this was when i was reading some info on pspupdates in the forum.. here is the link.
.http://forums.qj.net/showthread.php?t=23379&page=19&pp=10
it probably wont be of much help. maybe the first 2 pages witch link to where i have already.. and a bunch of noob babble.. i am rembrant from pspupdates.. im sorry i know nothing of coding in c. or i would have a remote for all to use already.. alas all i can do is present you with the cat half skinned so to speak..
if you have any questions about ir pm me its really all i can do.. my rc background allows me to understand whats going on but i could never code it..
thanks again good [H] readers if anyone can do it you all can...
first..
also..
and ..
