Bageland2000
- Jan 19, 2013
So I built admittedly crappy PSU extensions from MDPC-X sleeving and automotive wire a few years ago. The results were OK, but as I've been improving my PC over time I wanted to use fully-sleeved cables that had expert craftsmanship and decided to splurge on CableMod cables for my Corsair AX860. They didn't have fully orange stock cables-- I'd have to order those custom at twice the cost,-- so I purchased the combo black/orange ModMesh-sleeved cables that were available at a reasonable price. Before I did though, I was assured by the rep (after asking three times before I got an answer) that they were indeed UV-reactive. They are, but check out the comparison picture and you be the judge. I've place my extension to the left of the CableMod cable. My honest opinion, they did a terrible job sourcing sleeving that is properly UV-reactive. But I want your feedback, check out the picture.
http://imgur.com/xEr73zf
They do however, look awesome in white light, no lie:
http://imgur.com/eM3DuZ9
