M76
- Jun 12, 2012
Question is simple, can I use a ps4 pro with a QHD display? Will it work or will it revert to 1080p?
Why do you need hdcp for games anyway, lame.I would like 1440p support as well for my monitor. The problem also is related to HDCP support. Anything higher than 1080p might require HDCP 2
So if I use a QHD monitor with a PS4 PRO, it will work as if it is a regular old PS4? Or will games look and run better? Will it still render at 1440 just downscale to 1080?
