6tb hard drive...
Crap, the nyko thing is out already?!
It says some things might not work properly so your pic with nothing installed or tested doesn't say much really.
Im putting in a 2tb wd black for now. If it changes later i'll upgrade. Still wish they would just add external support but no rear usb kinda jacks that up
So you have to crack the case to plug this in? Void warranty I wonder?
Although why not replace the internal drive, hmmmm
https://www.youtube.com/watch?v=_0Gm5TiR93Q
Nyko recomends only using up to 2TB drives at this time."
Ps4 is pretty backwards on many things when compared to the X1 and this is one of the primary ones. They need to get this addressed or fixed soon.
/facepalm
You need to open the console to install a 2.5 inch drive. This connects to the same internal connecter, it just move the drive on top of the console since there isn't room for an internal 3.5. Using 3.5 drives opens up the console to use larger drives, or drives people may already have sitting around.
These are getting roasted on Amazon reviews right now.
Get what addressed?
Fix the fact that rest mode freezes if you use a drive over 2tb just like their last update that froze the system in rest mode if you left a disc in the system that's on Sony
Simple. Use the size hard drive you want BUT don't use the rest mode feature until it's patched. Problem solved then you won't have to deal with switching to a larger drive later on. I'm sure sony is getting slammed with complaints from people about it and a patch is in the works though.
If you can fill your PS4 with more than 2 TB worth of games, you might have an addiction problem.
i mean, by 2020 people will surely have enough shit to fill it with, no? 30 "full" games, and your 2TB is full. already possible today.
K thanks.
Thank you sir.
Obviously it's much less of an issue with physical copies,
but it's entirely possible that 2TB will not be enough down the line. Currently it's plenty adequate..
Retail discs install a portion to speed up load times I believe but otherwise don't do full install? I could be wrong on that.
I'm pretty sure that Save data and Install data are separate. I've deleted installed games but if I install the saves are still on my console.
Sony needs to add external drive support asap. I don't want to crack open my PS4 and redownload half a terabyte of games. They don't even offer a tool to transfer your drive making it painless.
Sony added support to do a full backup in a recent update. You can dump every bit of data on the PS4 to an external drive and then use that on a new hard drive (after you install the OS)
