One thing about the PS3 that I will say...it doesn't like HDMI for all TV's. Mine randomly stops sending a video image every so often and it won't for 2-3 hours. Components work fine, but HDMI's a weakness. I've tried 2 different PS3's and 3 different HDMI cables, too...yet my DirecTV box works like a million bucks through HDMI and has no issues. I have HDMI 1.3 and a Sony TV, too.
If you hunt around, I'm not alone. There are other people with similar issues. Although no 2 seem to have the identical same program, they're almost all HDMI hook-ups.
Just want to clarify that the PS3 isn't TOTALLY worry free. I've had my 360 since launch with no issues.
Armored Core
FF Series
Devil May Cry
MGS
Those are the major sellers for me.
Also said in the post by “DevelopersHeart” is that the Emotion Engine and Graphics Synthesizer chip will be removed in North American and Japanese consoles in April, unifying the two territory’s machines with the European spec.
Well now that Sony is rumoured to cut the EE chip from the US units in April, you might have to buy now if you want to be able to brag about your leet collectors PS3 in a few years.
I'm tempted to get one, hopefully they will keep the emotion engine active while adding software bc to those titles that support it. That way you get the best of both worlds.
http://www.dailytech.com/article.aspx?newsid=6301
What you are failing to understand is that running in software will make upscaling games easier. EE+GS will be disabled in current units via firmware anyways. Future firmware updates will include better compatibility with PS2 games.
Thus, not having hardware EE+GS is not going to kill you. It will be disabled later anyways. Phil Harrison mentioned PS3 will upconvert DVDs in future update... about time!
Armored Core
FF Series
Devil May Cry
MGS
Wait. My PS3 has maybe a literal millimeter or dust on it. I haven't used it since I bought it back in December. Wait until the end of April at least. Apparantly, there are a lot of great games coming out this month.
Now that all the launch hype/complaining is pretty much done and over with. When do you guys think is a good time to purchase a PS3?
My "quiet" 360's giving me sporadic problems and I'm considering the switch !
probably on 6/6/09 or so when the new slim version comes out.
If I get a PS3 it won't be until the thing is around 200 bucks cheaper, for the 60 gig model.
Yes, you will be waiting a while before they even think about dropping the price.
Yup, and as of now I have no problem waiting that long.
