Stereophile
- Dec 4, 2003
Ok so I hooked up my PS3 to my SDTV and it looks ok but I want hi res.
I want to hook it up to my LCD monitor but can't find the right adaptor ?
(My lcd monitor only has VGA input)
This morning I bought an HDMI to DVI cable at radioshack.
Then I was going to use my DVI-VGA adaptor that came with my videocard
and connect a regular VGA cable between that and the monitor.
Well the cable I got at radioshack is HDMI to DVI-D.
And the adaptor that came with my videocard is DVI-I to VGA.
So of course it won't work. I just talked to Fry's electronics and they said
they don't have anything like that. Only HDMI to DVD-D like radioshack.
Anyone know where you can get HDMI to DVD-I or even HDMI to VGA ?
