Project Thief - CaseLabs TX10-D Dual Workstation/Gaming Build - Gulftown and SB-E
The other side' door opens to reveal the "dark" side:
The TX10 features panels that can be removed in seconds to get access to the hardware underneath:
Behind the wood panels are four Alphacool UT60 radiators each with 6 fans:
The TX10-D can fit two HPTX sized motherboards, we only used EATX however. It can also mount server rack mount gear - at the top of the rear you can see 4x1u covers. 4 power supplies are supported by default, though more can be added. We found a 1500W and a 1200W PSU to be sufficient ;)
The "Light" side features the Rampage IV Extreme with a 4930K CPU clocked at 4.75GHz and kept very cool by a polished CSQ EK Supremacy block. The motherboard VRM and south bridge is fully water cooled also by EK water blocks in Nickel/Plexi CSQ polished by hand to a glass like finish. The RAM is Corsair Dominator GT 2133 CL9 - 8x4GB of DDR3 again fully watercooled by EK Monarch Blocks:
The tubing is Monsoon hardline acrylic tube coupled with Monsoon's Premium hardling fittings. These fittings grip the tube so securely they can hold up a 30lb dumbbell:
The motherboard chamber also features two EK X3 reservoirs in 400mm size. Large reservoirs make loop filling easier and putting them in an easily viewable window makes leaks obvious. The motherboard is easily removable as it sits on a removable tray. However the cooling is also quick to remove as each feed uses a Koolance Quick Disconnect. The motherboard can be removed for maintenance or changeing parts within a minute.
The dual 7990's also feature custom chrome plated backplates:
As well as MDPC-X sleeving and Lutro0 Custom's cable combs:
EK's clear terminals were used to keep the consistent style:
EK's Ekoolant in blood red was used to make the most of the plexi blocks:
Tubes were bent using Monsoon's pro bending kit which gave me professional results even though this was my first hardlined build:
I like to think that these chromed backplates are what caused EK to start making backplates in other colors than black ;)
The rear fan is a bitfenix sceptre in white with red leds. The motherboard chamber is also lit with RGB LED strips at top and bottom that are remote controlled:
The dark side of course is reverse atx:
The EVGA X79 dark motherboard is well matched to the EVGA SuperNova NEX1500 power supply and the EK X3 400mm reservoirs flow directly down in to the D5 pumps with EK tops:
R9-290s in quad crossfire providing the gaming power:
You may ask why not nvidia - generally quad scaling seems to be a bit superior with AMD even if Nvidia has the edge on single card performance. Lightboost of course still works with AMD, and now that I'm done with the build I can focus on getting some Swift monitors :)
LED strips reflect off the custom ebony veneered panelling:
Close up of the EK X3 anticyclone acrylic:
Monsoon fittings and hardline tube was again used to give an ultra clear look feeding into the EK Supremacy EVO block that cools the 4820K:
As this was a gaming computer primarily I went with a 4820K to acheive slightly better clock speeds, as that seems to influence high fps more than cores do though that is starting to change for some games. I love bridges to connect GPUs - they not only give a clean look and make hooking up the blocks easy but they also give a rigidity to the cards that can help reduce sag:
Some people have problems fitting them because it requires you to be comfortable sealing a block with an o-ring - but honestly if you are water cooling then you should be comfortable with taking a block apart and resealing it anyway. I also love the clean look of a backplate - and the EK 290 backplate also includes thermal pads that help to keep the hot R9-290 VRMs and core a little cooler:
The X79 Dark was one of the very few boards that EK did not make a motherboard block for. Luckily Natemandoo stepped up to make blocks for the board instead. Hopefully we will see some EK blocks for the EVGA x99 boards now that EK also supply the classified waterblocks:
A motherboard full of GPUs is a joy to see:
Powered up with RGB leds set to red:
You can see an error code on the motherboard simply because there is no boot drive or monitor connected. I need to have some friends over to help me carry this 100-200lb behemoth upstairs.
All the radiator fans are Gentle Typhoons. Some are 1850RPM while some are the 2150RPM units shown here:
Gentle typhoons can't be beaten for noise/airflow performance through a radiator, and running in push and pull means great performance while being able to dial them down to silent levels.
The bottom radiators even use 120mm Gentle Typhoons even though they are 560 sized. The use of a 120mm->140mm fan adapter makes this possible. You can also see the 4 screws (2 at either end) that hold the radiator side mount in. This side mount makes it very easy to remove radiators for cleaning out dust:
Even the Mora 1260 radiator (140x9) does the same thing:
The red ringed fittings are fill ports - one for each loop making filling a breeze.
The amount of display outputs just gets silly:
The monsoon hardlining is great for "mounting" pumps too. As it can carry significant load the pump itself can simply hang rather than being mounted:
This also has the benefit that vibration isn't transmitted through the mount. It even works with the EK Dual D5 top:
While the EK Ascendacy fan controller controls the fans and can measure temperatures I wanted to be able to have a quick glance to check out my coolant and air temperatures and so I built in these Phoby temperature sensors into a wood panel on the pedestal:
The temps here are a little off as the computers are powered on, and the pumps were not running so they're not indicative of real performance yet ;)
Lastly the LED strips that are pretty well hidden in each chamber at the top and bottom:
Here are some vids that show the LEDs cycling through colors:
http://youtu.be/LvSCPImtu5Y
http://youtu.be/nBoBcF-hfTo
So that's it from me and thief and it's nearly time for us to say goodbye, throw a party and move this fridge sized beast upstairs! Again a big thank you to sponsors for their generosity in making this long project happen!
I'm building in an S8 right now and I thought that was pretty intense. This thing is like a skyscraper when everyone else is building with Legos. Well done sir.
Thanks! GL with the S8 build, it's a great case!
My wife saw the base case labs case a while back.. now when i say I have an idea for a computer build.. she says "No you don't" before i even finish the sentence lol.
Some people have a water cooling system.. you got a system that makes water companies jealous
Sliced bread saw your final build and took off running...
what i'm saying is.. very nice :)
@stren
42 fans in total? How do you control those, i dont see a fancontroller in there?
You are either going to amaze me how you managed to control those fans and still keep it quiet , or you have a hearing problem. :p
Amazing work! Absolutely love the cable management.
