Vaulter98c
[H]ard|DCer of the Month - October 2009
- May 21, 2008
OK, so since the other guy has not finished (or even log'd in lol) in a long while I'm going to do my own NES case mod, but while trying to cram in a respectable amount of power too.
I've seen too many Atom or lower builds done in an NES case, all the IGP's suck on those, and the CPU's are cut down laptop versions to boot. Also, most documented NES case projects were from a time when CD/DVD drives were needed. Now, not so much.
Anyways, the goal here is to put a fast Sandy Bridge CPU with an actual GPU, 8GB RAM and a .5 TB HDD into a NES case. Hopefully if I can do it the plan is to have an emulator build capable of running everything PS2 and down, altho mainly the classic retro systems are the priority here, PS1/PS2 isnt needed due to my PS3 and PS2 is really just a target to shoot for. It would be nice to also have a small gaming rig I can move around the house incase I wanna lan or take it with me.
Problem is, to the best of my knowledge, nothing like this has been tried, GPU's werent small enough and those that were werent usefull in a mod like such. Now, we have powerful low-pro cards than can accelerate gaming, media, and emulation. So, as you will see in the pics, this is the dry/practice run. This case will be getting sacrificed to find the best way to make this work (if I even can lol) before I do the actual one I'll keep. That being said, at some times the project may look like a bad hack and slash job, that's ok, I'm trying things out lol. O yea, and I'm no pro, this is my first try at ANYTHING near this level lol, so go easy on me lol
So first up, parts list. Here's what I have. Not everything is actually in hand yet, but everything listed here is ordered and on its way.
PARTS
NES Case - just a normal NES case, not cleaning it up since this is my practice run before I do the final mod
i3 2125 Dual Core (4 Thread) 3.3 Ghz
Corsair 8 GB 1333mhz PC3-10666 240-pin Dual Channel DDR3 Memory Kit
GIGABYTE GA-H67N-USB3-B3 LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard
HIS Radeon HD 6670 1GB 128-bit GDDR5 Low Profile Ready Video Card (this thing is beautiful lol)
Western Digital Scorpio Black 500GB 7200 RPM/16MB 2.5" SATA II Notebook Hard Drive
Mini ITX Power Supply Kit PcioPSU 150-XT + 144W AC to DC Switching Power Supply
3 Pin Female to 2 x 3 Pin Male Connectors Fan (3x of them)
Scythe 40x40x10mm Fan 2 pin with 3 pin adapter. (4x of them)
Coolerguys 80x80x15mm 12v Fan 3 pin
2x PCI Express flex connectors, diff vendors so I can hopefully get one good one between them lol
This project page will be getting worked up and fancied up over the next few days, but I wanted to get this up here online first
Also, I'll be going out of state for some more Army missions in 3 days, be gone for 3+ weeks, so there will be a big lull period, but I want this online so people can weigh in with options / ideas / suggestions for ways to not only make the final project better but to make everything fit in the same damn box lol
PARTS
