Hey Folks,
Its Summer again, and time to start another case mod J I had so much fun with my case modding last year, I could not wait to start a new case mod this year, and capture it in a worklog. So with that being said, lets get into the fun stuff.
Background:
Last year, I modded 2 CoolerMaster Centurion 5 Mid Tower cases (Tribal Eclipse and Dragster), which was a blast!! I wanted this years mod to be a little different. The hard part about modding a mid tower case is that transportation is a pain. The case is just so big and cumbersome to carry to LANs. For this summer, I have decided to mod SFF cases (Small Form Factor).
Initial Ideas / Concepts:
I want this SFF case to be as fast and as powerful as a normal desktop system, just in a smaller form, and at the same time be unique.
So I have decided to merge 2 Hornet SSF cases into a single case. The problem is that combining 2 Hornet chassis will make the size comparable or if not larger then a normal mid tower case. So I will be cutting one of the chassis to approximately half its original height. The half chassis will serve to house all the water cooling parts, such as the radiator, pumps, and what not. The final case will have the same foot print of the hornet, but slightly taller.
Here are some of the Goals for this case mod:
- Water-cooled
- High Performance (SLI)
- Totally Pimped Out
- Killer Paint
Deadline: End of August. Yup, about 6 weeks to do a fully modded case. Lets see if I can pull it off.
First Post / Case Overview:
Here are some initial images of the hornet, as I disassemble all the parts and measure the pieces. My Dremel went MIA, so cutting updates will not be shown till the next post L
Here is a picture of the 2 Hornet cases side by side in its stock form:
Here is a picture of the 2 hornet stacked on each other from the front view. Two full size hornet on top of each other is just too tall.
Here is a side view of the stacked hornet.
Here is a picture of the rear of the hornet. As you can see the hornet is designed for a mATX PSU. Hmm.. running SLI and Watercooling, a mATX PSU wont be able to meet the power requirement. So I will be increasing the POWERAGE of the unit
Removable motherboard trays are always great to work with.
Here is a picture of all the internal guts of the case.
Here is the just bare frame after all the side panels and internal components have been removed.
Well, that was a little intro to my upcoming case mod. Since this mod needs to be done by the end of next month, updates should be coming up fairly quickly.
Any comments, suggestions, or input would greatly be appreciated.
Regards,
SAD
Background:
- Water-cooled
- Killer Paint
Regards,
SAD
