So I tried watercooling once....it didnt turn out very well for the most part. I got water all over my wood floores, fried a mobo, and algae ate my video card. With that said, I'm gonna try not to ever do that again
And if you're wondering about the title, when I last attempted to do watercooling, my now ex-girlfriend said 'Oh my god! Theres water in your thingy?!'...and to which I replied 'What thingy, the computer? Yeah, its called watercooling...' And she says 'I dont speak greek what are you talking about?' And that was the end of that conversation...
So instead of trying to cheap out and build a WCing kit from 150$...I'm gonna go the profesh route and buy new things that work properly
Starting with the goods:
ORDERED: August 2nd, 2005
www.voyeurmods.com-
Red UV 3 1/2" Floppy Bay Resevoir 3/8"ID Fittings
PolarFLO TT Series Copper CPU Block 3/8" for LGA775
PolarFLO TT Series Copper VGA Block 3/8" for ATI Series Graphics Cards
8' of PrimoFLEX RED UV Tubing
www.dangerden.com-
Black Ice Pro Radioator 120MM BLACK 3/8" Fittings
DangerDen (Swiftech) MCP350 3/8ID Low-Profile Pump
FREE- MCT-5 Non-Conductive Solution (Dont know what this stuff is but it was free!)
So I got my WCing kit pretty set up that should get here by Friday Aug. 5th.
Now I need to get my hardware together, heres what I have now:
Pentium 4 570J 'Engineering Sample' 3.8GHZ 1MBL2
Lian-Li Pc-7B Plus (Dual 120MM + 1 80MM Exhaust)
Enermax Coolergiant 480w PSU ATX2.0
2x120GB WD SATA's
2x512MB GEIL DDR2-533 PC2-4300 Ram
This needs to be ordered on Monday, August 8th, 2005 when I have more money in my PP account:
ASUS AX800XL 256MB Video Card
ABiT AL8-V i945P Chipset Motherboard with uGURU
Now with the case modding, I need to take a stop to Home Depot this weekend. Need to get some rubber washers to silence the fans and window edging molding to cover up the ring of the 120MM fan holes to make it look neat.
I'm thinking of mounting the Pump with two screws and Rubber washers to help with vibrations, under the 3.5" rack upside-down. OR if its low-profile enough, I will mount it inside the rack under the 3.5" bayres.
Work on this should start next monday, just gathering ideas...
www.voyeurmods.com-
www.dangerden.com-
2x120GB WD SATA's
