UrbanSmooth
- Apr 23, 2011
What's up!
First post here at [H]. I have been browsing this forum for years, finally decided to join up when I saw how well-developed the SFF section here is. I answered the questions, so, feel free to post input, thanks:
1. What will you be doing with this PC? Surround/Eyefinity Gaming, Photoshop (or other intensive programs), Overclocking, Web browsing.
2. What's your budget? Unlimited, yet within reason.
3. Where do you live? Madison, WI, however, I will be doing online shopping for this build.
4. What exact parts do you need for that budget? CPU, RAM, GPU(s), SLI/CXF-friendly/ready PSU, Optical Drive, Headphones-friendly Sound Card, Intel NIC, case. Water
cooling: CPU water block, GPU(s) water block(s), Pump(s) w/ pump top(s), Reservoir(s), Tubing, Fittings, Quick Disconnects. Bling: UV Lighting (led strips, or...) Color
scheme/theme: Orange, Black, and White (or best recommendations if color scheme/theme not met)
5. If reusing any parts, what parts will you be reusing? None.
6. What specific features do you need in a motherboard? SLI/CXF x16 or x8 capable.
7. What resolution output do you need? Triple monitor support for up to 5760 x 1200 resolution.
8. Does this system need to fit into a particular space? Smallest case possible to fit all items comfortably, yet SFF-ly, will most likely be on a desk next to the monitors.
9. How comfortable are you with custom case design/modification and electrical wiring? Comfortable enough; will Dremel, drill, and solder.
10. How important is the noise/silence of this sytem? As silent as possible, but, won't give up considerable performance for less noise.
11. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
Mobile enough to pack up in as small amount of space as possible for vacations, business trips, and LAN parties. I don't mind handles.
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Yes, W7 64 Home Premium.
13. When do you plan on building/buying the PC? As soon as all of the parts are available and decided upon.
