Mr_Armageddon
- Jun 3, 2009
Introduction
It's time for another custom Liquid Cooled build, and this time we are utilizing the MASSIVE Thermaltake Tower 900 case! This is a commissioned build, using some extreme hardware, and I am really excited to get started.
Will feature dual liquid loops, one for the i9-7980 Extreme CPU, and the other cooling 2x Nvidia Titan X Pascals in SLI. We will incorporate a little bit of acrylic work to clean things up, along with some painting, and RGB lighting. Take a look at all the components below to see just how impressive (and powerful) this build will be when completed. I present Project Ecthelion!
Component List
Component Type (PC Hardware)
Build Log Project Index
Component List
- Case Thermaltake Tower 900 White x1
- Motherboard ASUS Prime x299 Deluxe x1
- CPU Intel i9-7980XE Extreme 18 Core Processor x1
- RAM G.SKILL 64GB (4 x 16GB) TridentZ Series DDR4 PC4-27200 3400MHZ x1
- Video Cards Nvidia Titan X Pascal x2 SLI x2
- GPU Backplate Titan X Design x2 Color Backplates x2
- SSD NVMe Samsung 960 Pro M.2 2TB x2 (RAID) x2
- SSD 2.5in Samsung 860 EVO 1TB x1
- Power Supply EVGA SuperNOVA 1000 P2 80+ PLATINUM, 1000W x1
- Custom Cables Blue and Black sleeved x1
- OS (Dual Boot) Windows 10 x64 / OSX (HackinTosh)
- Fans / Lighting NZXT RF-AR140-C1 HUE+ & Aer RGB140 Fans Bundle Pack x1
- Lighting NZXT HUE+ Extension Kit LED Strips x2
- Reservoir / Pump Thermaltake Pacific PR22-D5 Adjustable D5 Pump/Reservoir Combo x2
- Fans (Radiator) Corsair ML120, 120mm Magnetic Levitation SP Fan (2-Pack) x3
- Radiator XSPC EX360 High Performance Radiator x2
- Tubing (Hard) Monsoon Hardline PETG Tubing 1/2" ID, 5/8" OD (16mm) 36inx3 x1
- Tubing (Soft) PrimoFlex Advanced LRT 3/8in.ID x 5/8in.OD Tubing Bundle (10ft pack) x1
- Fittings Monsoon to 1/2" ID, 5/8" OD Hardline Eco V2 Compression Fittings x6 x3
- Fittings Barrow G1/4" Fittings (Various) x46
- Fittings XSPC G1/4" Ball Valve, Black Chrome x2
- Waterblock CPU EK X299 Monoblock x1
- GPU Waterblock Watercool HEATKILLER for Titan X Pascal - ACRYL Ni x2
- Coolant Additive Mayhems Pastel Concentrate White - 250ml x1
- Coolant Additive Mayhems Pastel Concentrate Blue - 250ml x1
- Misc Barrow Replacement G1/4" O Ring - 10pcs - Blue x2
- Display Toguard 7 inch Ultra-Thin High-Res 1024x600 HDMI Monitor x1
- Misc Flat Slim High Speed HDMI Extension Cable x1
- Misc USB 2.0 Male to Micro USB 90 degree Angled Cable x1
- Misc DC Barrel Power Plug Pigtail Cable 12v x1
- Intro / Component List
