Project... black... maybe
ATLPIMP
Well, it's black.
Started out as an Antec SX1040. I've decided to rework this old trusty case. I've always wanted to do black, but have been influinced by others. Now, it's my turn.
The window is designed to go around the handle, like the window on my other Antec.
OLD:
http://www.gruntville.com/casegallery/albums/MyWorkInProgress/window.sized.jpg
NEW:
http://www.gruntville.com/casegallery/albums/MyWorkInProgress/sideprime.jpg
The new window is cut to give more view of the CPU/RAM/VGA, or lack thereof.;)
I went ahead and modded the chassis to accept a chevette heatercore for a later project.
http://www.gruntville.com/casegallery/albums/MyWorkInProgress/guts.jpg
Next on the list will be an Orb VGA cooler to get rid of that long wire hanging across the case.
Now, here's the other side of the case with the first color coat. Still need to wet sand w/ 600 grit, second coat, then clear coat it.
No pics of the bezel, because I'm not done with it. I'd like to shave the raised power switch. Then bondo all the holes, add a Belgian (right name?) switch as the power... ridding the front of a reset switch. Then I'll be modding some custom power/HDD leds into the front of the bezel. Somewhat hard to describe...
Here's a picture borrowed from a fellow forumer:
http://www.gruntville.com/casegallery/albums/MyWorkInProgress/untitled.sized.jpg
Now, where you see white will be plexi. I'll cut slits up the bezel, with my trusty Dremel. Then, wedge some plexi in, mark it flush with the bezel, then cut it. I'll go back and hand sand it flush with the bezel. I'll then drill one hole in the bottom of each piece of plexi (~5mm) for power and hdd LEDs. The red will be hdd and blue power. I'll only drill one hole, because I think the fading light will look better than a solid light.
Later on down the road, I'll buy some of these:
http://www.xoxide.com/suledcafebre.html
With these, I'll mask off the whole foot, save a small strip around the bottom (so only the bottom glows... it's floating! ahhh!), and paint the rest of the feet to match the case.
This case doesn't have blow holes and fans everywhere for one simple reason. I don't like the noise! You noticed the 120mm Papst intake (future radiator fan), and one single Panaflo L1A exhaust. The TMD fan is actually very quiet at 7V... and still cools the 1800+ at 2.1GHz. Hopefully updates will be plentiful... and come soon!
Ran out of paint early this evening, needed to replenish the arsenal. I finished fine sanding the panels (1000 to 1500 grit[wet]), and rubbed them out. Got the plexi window mounted. that was tricky trying to cut the plastic around the handle area of the Antec. Go, no go...:D
http://www.gruntville.com/casegallery/albums/MyWorkInProgress/windownew.jpg
Still don't think I'll be painting the feet. Not worth it. In the next week or so, I'll have those glow in the dark deals.
http://www.gruntville.com/casegallery/albums/MyWorkInProgress/frontbondo.sized.jpg
With the new LED placement on the front, I got a little carried away, and went too wide. Slid in replacement plastic (to keep the fit the same), and slapped some Bondo in. Man, is this stuff fun! I kept thinking of things I could Bondo after I did my bezel (door). I think these LEDs will look trick. I sanded down the plastic with some 80 grit to rough it up, then went to a 400, and got just the right effect.
Hopefully everything's done by tomorrow night... Got to take the girl to see Torque, riding the bike of course.;)
not bad, but why such a generic window
i know its curved and doesnt look bad, but still
and those led feet, why bother if your going to be painting everything except the bottom
mod the feet you have now :D
get some plexi, leds, and dremel away, mount the leds with hot glue or something and put the plexi on the bottom
more work maybe, but the results would be awesome
hope i didnt offend you, just trying to give you some constructive criticism
your case is coming along nicely, very clean paintjob :D
Well, some replies, better than none.
I was also thinking of the LED plexi feet. The acrylic that I would get is pretty expensive. Along with the LEDs I'd need (at least two for every foot (8).;)
Looks pretty nice. I suggest you put some lights in your case or something because it looks plain on the inside.
