Project: Black Death
Hi
Maybe you know my case from other forums
I use the lianli v1100b case which is very noble, so i decidet to make an very discreet mod.
A composition of black aluminium, carbon and uv-plexiglas inside of the case.
Except of the radiator and the pump all water blocks are custom made.
The name of the project is according to the pest plaque in the 14th century
(why? i dont know :D )
Sorry for my bad english but i am from Germany.
So lets start:
First of all the case:
At the beginning i removed all useless parts in the case
then i used a dremel to cut a 120mm hole in the bottom of the case
(quite ugly but later you cant see it)
this hole is for the fan of the aqua-computer airplex evo radiator
mounted here
now it was time for the internal space
here i use mirror plexiglas to get a bigger and cleaner look
i wanted to have an very special reservoir in front of the mainboard
so i cut some plexiglas
this is the first test
the next step are the waterblocks
first the cpu block
i took 5mm copper and drilled 16 holes in it
then i made the first plexiglas top
then the last top and all other parts
(first i made blue plexi parts, they´ll be orange later
the first test of all parts
at night
then the first test in my old case
then i bought a new aquastream 3.5 from aqua-computer
this is a great pump
my ram is very hot so i made a fan holder
this are 2 stripes of uv-plexiglas and one 1mm plexiglas
it fits perfekt in the 4th ram slot
now i went on to build the water blocks for my x800xt and the nf4 northbridge
first i made a positioning device
then i saw some chopper
after some soldering
it is very thin
the same with the northbridge cooler
the mounting is made of uv-plexiglas
and now the final water block in my old pc for some testing
i went on with some "boring" stuff
first some new mirror in the case
then i bought a aquastream
the controller in the front
the aquastream buffer
and a overview; aquastream and airplex evo 120
i nearly finished my custom reservoir
enjoy it :D
after some gluing with acrifix, today i started my first test of the res
and it is leakproof
:rock:
then i installed all water blocks and hardware in the case
first of all the corsair ram cooler in detail
then the harddrive
the complete view in daylight
and at night
at the moment i am waiting for some materials
el rolio
wow that ram cooler is awesome. well actually all of it is awesome, custom and all! good job man! i would love to see some more or have you write up some more about this ram cooler and how a dual fan setup might work and how you got the bit to fit in the 4th ram slot etc.
shadowlord
very inovative ram cooler
that gfx cooler is badass :D shows you're high skills
but wouldn't the coolant get dirty trough the open res?
Majin
I have never seen such a creative Video Card cooler, all hand made to boot.
THAT'S VERY AWESOME WORK!
JOKER_JOKER
I agree with El Rolio. Can you tell us how you mounted the fan bracket inside the 4th ram slot? That is crazy.
BoySetsFire
excellent craftsmanship!
one thing i don't like though is the mirror finish. it makes the inside look cluttered. i prefer a clean, sparse look. anyway ... great job!
LunchboX3904
whoa!! awesome job dude! Like everyone said, very nice and original coolers. That res is really cool too. You should keep it so that it's a little fountain in there still....maybe put in some UV dye.
P.S. your english is just fine. a lot better than some others I have seen. ;)
Awesome job man.
I especially like the innovative ram cooler. I have never seen this before.
Would you mind if I "borrowed" this idea to cool my ram? :D
Very nice job so far man!
I'm loving the custom waterblocks and ram cooler =). Maybe try this though, try shortening up some of the tubes on the ram cooler? It might look a lot cleaner instead of looping them like a O formation.
thanks @ all for your compliments :)
@DarkenReaper57
no problem, it is allways a compliment when somebodys "borrows" my work ;)
the only "condition" i have is that you´ll make some pictures :D
@LunchboX3904
i love the small fountain in the res, if it would be bigger, the pump and the plashwould be louder
so it is a good compromise
@JOKER_JOKER/el rolio
for the corsair ram cooler i used a stripe of 1mm acrylic glas and copyed the contours of the ddr ram
then i made 2 stripes of uv-reactive acryl formed them at ~160°c, mounted the fan and glued the 2 stripes at the ram copy
so i am able to push the complete cooler into the ram socket :)
quite simple
@shadowlord
the complete mod is not ready yet
the res gona get a cap
Hmmm, where did you get the plexiglass for your res and other things?
Also, what exactly did you use in the ram slot? A piece of metal or plastic?
compslckr
oh god, time to change my pants... again...
that looks sweet! i love it. nice plexi work!
Oneos
He used a 1mm think piece of plexi.
I'm not quite sure but i'd hesitate to use metal in my RAM slot :p
Yeah, I was thinking the same thing. It really wouldn't matter as long as the metal didnt come into contact with the metal pins, though.
penguin
How does your CPU block perform? It looks like it would be pretty easy to make, and there are still quite a few people who make their own waterblocks.
Overall, very nice work!
Stormlifter
Excellent job... woah... some of that cooling I don't even understand, especially that bent pipe in the middle of the case that seems to have ice in it in one of the pics... what the heck is going on here :)
Nice pics too btw, very crisp
apHytHiaTe
Man! This is fucking great. You are the shit.
I saw this on BT, and I was floored. This is one of the most elegant and completely hand-done mods I have seen of late. You, sir, deserve a medal for your efforts. Hope to see more soon!
Good luck and ModSpeed.
FadedSpark
wow, thats some l33t ass looking waterblocks 0_0 and your rig is more UV than Revenants! nice work man! :D
ericlikeseatin
as everyone has already said, great job man.
i think if you started making more of those ram coolers, you would have quite a few people wanting to buy them off of you!
Shogo
how did you get that mirror finish?
I just ordered the same case, waiting for it, and i was wondering how cool it looks with a cool gear inside, and as i can see yours is killing!
Project_2501
I have a question about the ram cooling, do you have an idea on how to fabricate something to cool 4 ram chips (512mb UTT) with an 80mm fan? You'd need to clip something to the side, I'm curious though. I have the same motherboard, and your work is superb.
Thanks in advance.
awdark
so you use acrifix to glue all that stuff together? Neat
Er and you made your own waterblocks? Thats neat stuff how did you make the ones on the video ram? I have seen worklogs of people making waterblocks but never memory sink blocks.
[DGN]Nexus
I was also curious as to how the custom waterblocks perform. I am also curious how exactly it works, cuz I see the 16 holes, but I don't see the space inbetween the plexiglass and the copper for the coolant to travel. thnk for the info in advance, and sweet work.
thanks :) :)
@DarkenReaper57
it is plexiglas
@penguin
very good
a64 @ 2600mhz @ prime95 @ max 42°
but you know, you cant trust temp sensors
@Stormlifter
this pipe is the res
the ice you call it are small pieces of glas
it should look like ice
@Project_2501
this is a bit difficuld but you can solve it
maybe ill try some things in the future...
@matt00926
yes
ok now its time for the window
to get a straight line
finished
i uses some special plastic film
first test
inside dark-outside light -> mirror
inside light-outside dark -> the window is clear
;D
it is a special film
you only can see inside the case when it is light in it otherwise it´ll be a mirror
Project_2501
How would it fall over? The thing is like a tank.
And, thanks for the reply. I really don't know where to start to mount a cooler on the ram w/o using a slot...
atom
I like the small window but now you have to do something to the rest of the panel its blank.
