UrbanSmooth
- Apr 23, 2011
Here's the plan for a water-cooled mini ITX media PC in a shoebox-style case such as the SG05, utilizing a FULL water-cooling loop, cooling both the CPU and GPU with two 140mm radiators:
The main thing with this is how the PSU is oriented toward the back of the case so that a fan and radiator can fit in the top. The air flow would bring cool air in, passing through the top radiator; the PSU fan then pulls air from the radiator out of the case, cooling the PSU. This can be done by modding the case, simply cut a new PSU mounting hole in the desired location. Exact measurements will vary from project to project.
This is really kind of a mock-up idea to throw out there at the SFF community, however, I will try to follow this mock-up for my next build and first SFF build.
