masher said:Which is as it should be. Businesses that don't put profit first don't survive.
Qtip42 said:Got a hold of some perforated steel today and cut it down around the power supply. I'll have pics tomorrow night some time. Gonna get a wifi card and see if the shop computer can pick up the router in the house as a temp for the webcam. 300+ feetMight need a more than just a card heh.
themark said:More likely they'd pay some lawyer to step on it. Keep away from the studios, their only interest is profit and copyrights.
Qtip42 said:Arbor press. Helps to have a hydraulic one. The dies cost a lot though.....
Qtip42 said:Louvers:
Qtip42 said:putting an x800xl in. Don't worry about the airflow, I'm not done routing stuff yet![]()
CrimandEvil said:I was wondering, where did you get a PCIe riser this is in that position? I'm trying to track one down right now but I'm only able to find the ones that go along the PCI cards area.
gulp35 said:if you have any clearance for it, pond rubber can be used to make a good gasket/vibration damper. I've been using it on my HAL9000 Mod to try and keep noise down (hard to do in 2U).
Still looking forward to the completion of this mod.
What would you say your most used/valued tool would be on this mod?
CrimsonSky said:Qtip you sexy bitch, the updates look great!Wow are those socket head cap screws I see
SpangeMonkee said:do you think that people with a little less cash flow could do that with a wood jig and some bfi?
altec said:Is that video card just setting on the metal.![]()
