three_sixteen
- Feb 15, 2002
Got a wierd problem here, can't seem to find anything on google about it.
I'm trying to install Adobe Indesign CS.
The program runs through the install process fine and immediately afterwards either the installer program removes the files it just installed.
I've got a little clip of a filemon log I took while the program was installing.
Here it is creating the file..
And here it is deleting the file..
This is being installed using a legitimate key for Adobe, all of the other components install fine, but for some reason Indesign is uninstalling itself.
Code:
PM zidxp.exe:2100 CREATE C:\Program Files\Adobe\Adobe InDesign CS\Samples\Womefd93.rra SUCCESS Options: OverwriteIf Access: All
108792 1:10:18 PM zidxp.exe:2100 OPEN C:\Program Files\Adobe\Adobe InDesign CS\Samples\ SUCCESS Options: Open Access: 00000000
108793 1:10:18 PM zidxp.exe:2100 WRITE C:\Program Files\Adobe\Adobe InDesign CS\Samples\Womefd93.rra SUCCESS Offset: 0 Length: 32766
Code:
116705 1:12:23 PM zidxp.exe:2100 CLOSE C:\Program Files\Adobe\Adobe InDesign CS\Samples\Womefd93.rra SUCCESS
116706 1:12:23 PM zidxp.exe:2100 OPEN C:\Program Files\Adobe\Adobe InDesign CS\Samples\Womefd93.rra SUCCESS Options: Open Access: All
116707 1:12:23 PM zidxp.exe:2100 QUERY INFORMATION C:\Program Files\Adobe\Adobe InDesign CS\Samples\Womefd93.rra SUCCESS FileObjectIdInformation
116708 1:12:23 PM zidxp.exe:2100 DELETE C:\Program Files\Adobe\Adobe InDesign CS\Samples\Womefd93.rra SUCCESS
116709 1:12:23 PM zidxp.exe:2100 CLOSE C:\Program Files\Adobe\Adobe InDesign CS\Samples\Womefd93.rra SUCCESS
