Program to use file names to add ID tags to audio files?
Discussion in 'General Software' started by mike_6289, Aug 30, 2010.
  1. mike_6289
    mike_6289 Limp Gawd
    316
    Dec 31, 2004
    Over a decade ago I started ripping my CD library to wave files and manually named them like this:
    01 Artist - Track.wav
    eventually converting them to FLAC
    I want to have them tagged, and while manually naming them during the ripping process really wasn't that inconvenient, now that I have a couple hundred albums it's impractical. Are there any programs that could be configured to do this?
  2. keenan
    keenan 2[H]4U
    2,696
    Aug 5, 2009
    It's not exactly what you're asking for, but I use MusicBrainz Picard for tagging. Basically you dump a bunch of files into it, tell it to scan them and it identifies them and tags automagically.
  3. Bahamut
    Bahamut n00b
    0
    Apr 27, 2010
    Picard as mentioned or MediaMonkey, both will get the job done. Those apps won't help with the WAV files, of course, but once you've got the content in FLAC or whatever format you want (that supports tags, of course) they'll be just fine.
  4. Nighted
    Nighted Gawd
    632
    Apr 25, 2008
    Mp3tag: filename to tag using something like this: %track% %artist% - %title%
  5. BodyBagz
    BodyBagz Limp Gawd
    333
    Jan 12, 2006
    I`ll throw out another vote for MP3Tag...it is a nice piece of software.
    I`ll also throw a vote for my go-to audio tagging software, Tag&Rename...I have used this for the last 5 or so years...never have to worry about tagging an album ever again for the most part. It will even pull tags from the file names and add in album artwork to the tracks/folders if you wish...:cool:
  6. mike_6289
    mike_6289 Limp Gawd
    316
    Dec 31, 2004
    this worked, except I had to put an extra space after the dash to remove a space that was in front of the track title in the ID tag.
    thanks!
