I refer to trunking in Cisco terms or HP's tagging.
I'm just starting to get a little bit deeper into our switched network, so please bear with my ignorance. I've got a Procurve switch in one building and a Cisco IOS Switch in another. Both switches are one network configured on the native vlan 1, talking to each other over a fiber access port. I'd like to create a second vlan for another network on the HP switch and extend it to the Cisco. I'd like to run this config process by you guys in case something about this won't work.
Procurve: What I'm trying to do here is establish a tagged port and put vlan 1 and 122 on it. Also create vlan 122 and assign some ports to it.
vlan 1
tagged 45 (current access port, make it the trunk port)
vlan 122
name new_vlan (example)
untagged a,b,c (need three ports for new network)
tagged 45 (trunk between switches)
Cisco: Basically I'm trying to do the same thing here, but vlan 122 will require a couple more ports.
#create vlan
interface gig 0/a - d (vlan 122 network ports)
switchport
switchport mode access
switchport access vlan 122
no shutdown
*** Do for all ports part of vlan 122
#trunk
Switch(config)#interface gig 0/x (the fiber trunk port)
Switch(config-int)#switchport trunk encapsulation dot1q
Switch(config-int)#switchport trunk allowed vlan 1, 122
Switch(config-int)#switchport mode trunk
At this point I'm hoping to have achieved traffic flowing on the default vlan 1 again as well as vlan 122 between the two switches. I have read and been advised that I should ultimately move my traffic off vlan 1, using it solely for management purposes. I fully plan on doing that however I'll be making this change in the early hours on a production network, so my config time is limited. Any and all advice and constructive criticism is appreciated.
vlan 1
vlan 122
#create vlan
switchport
no shutdown
#trunk
