Procurve 2420
StefanPeeters
Hi,
I have a procurve 1910 and a procurve 1810. I can connect both of these switches. I also have a procurve 2420 who I can't connect to. When I do a networkscan I get the ip address of the 2420 switch as 192.168.1.213. When I type that address in I get the famous page 'page not found' even when in the same subnet. Does anyone knows how to get into the webinterface of the 2420 switch?
Thank you
Factory reset?
Maybe the 2420 is using a non standard subnet?
I'd just reset it personally....
Have you tried connecting to the 2420's IP with https? Just a thought
Thanks for your swift reply,
I have reset the switch. This is the ip address after resetting it. I will try to connect the switch tru https later. I let you know how it went.
Thanks
