In a home setup involving Crestron home automation/AV control and Lutron lighting control, I'm trying to accomplish the following network segmentation w/ VLANs on an HP ProCurve 1810-24G v2 (but I'm not sure it can be done):
- Currently the network is not segmented and has no VLANs
- I'd like to have the Lutron able to "talk to" the Crestron, but otherwise isolated from the rest of the network
- I'd like for the Crestron to be able to still connect to the Internet and the rest of the network
As far as I can tell, this is very similar to the example given in this well-written guide, but using different hardware, and exchanging the VoIP in the example for my Lutron segmentation:
http://www.smallnetbuilder.com/lanwan/lanwan-howto/30071-vlan-how-to-segmenting-a-small-lan
Is the SRW2008 Linksys switch referred to there doing Layer 3 vs. Layer 2 on the ProCurve, and therefore more capable of doing this? Basically, I'd like to have something like this:
VLAN 1: Default/management
VLAN 2: Data
VLAN 3: Lutron
Port 1: Management [VLAN 1 & 2]
Ports 2 – 19, 21, 23: Main data network [VLAN 2]
Port 20: Lutron controller [VLAN 3]
Port 22: Crestron [VLAN 2 & 3]
Port 24: Uplink to router (AirPort Extreme) [VLAN 1, 2, 3]
I've tried tagging thusly:
VLAN 1 [Default]-- Untagged: 1, 24; Tagged: 2-23
VLAN 2 [Data]-- Untagged: 2-19, 21, 23; Tagged: 1, 22, 24; Excluded: 20
VLAN 3 [Lutron]-- Untagged: 20, 22; Tagged: 24; Excluded: 1-19, 21, 23
However, I'm not able to communicate between, say, the Crestron port (22) and the router (24) or other data network ports (e.g. 5), although the Crestron and Lutron can "talk".
It appears from looking at this thread that I might be out of luck: http://hardforum.com/showthread.php?t=1742558
I've also read through this thread, but can't seem to figure out how to match to my setup: http://hardforum.com/showthread.php?t=1742558
Can I have my VLANs arranged like this and still have some "cross-traffic" so that the Crestron can access the Internet and be visible to other network devices, or is the ProCurve unequipped to do this?
Thanks,
Fred
VLAN 2: Data
VLAN 3: Lutron
Thanks,
Fred
