Format _C:
- Jun 12, 2001
I am having problems with Handbrake (It all seemed to happen after the "Patch Tuesday" on 03/12/2013) I can load the program but as soon as I add a project to the queue it crashes with an error
I have tried reinstalling the program and compatibility mode does not work either. Is anyone else having problems with Handbrake since the last "Patch Tuesday"?
I ram memtest and all of my hardware tests out good.
I am stumped at what to do here any suggestions?
Thanks
Here is the error I am getting
OS is Windows 7 Home Premium SP1
Here is all of the text in the first box
Thanks
Code:
An Unknown Error has occured.
System.Exception: An error has occured in the QueryParser Utility. ---> System.FormatException: Input string was not in a correct format.
at System.Number.ParseDouble(String value, NumberStyles options, NumberFormatInfo numfmt)
at System.Double.Parse(String s, IFormatProvider provider)
at HandBrake.ApplicationServices.Utilities.QueryParserUtility.Parse(String input)
--- End of inner exception stack trace ---
at Handbrake.frmQueue.RedrawQueue()
at Handbrake.frmQueue.UpdateUiElementsOnQueueChange()
at HandBrake.ApplicationServices.Services.QueueManager.RestoreQueue(String importPath)
at Handbrake.Functions.Main.RecoverQueue(IQueueProcessor encodeQueue)
at Handbrake.frmMain..ctor(String[] args)
at Handbrake.Program.Main(String[] args)
