Hola
Tengo un problema con la placa Asus P6T Ws BIOS Profesional X58 version 1107, procesador Core I7 975 extreme y la memoria 6GB Kingston HyperX KHX2000C9AD3T1K3/6GX, 6 modulos de 12GB. he hecho bios X.M.P profile 1-DDR3-2000 o profile 2-DDR3 1866 Intel XMP Tall HS 9-9-9- todo correcto en Windows 7 64 bit. Pero cada día tengo el mismo problema, se me cuelga. Me aparece en pantalla azul:Dumping physical memory to disk. No puedo trabajar,¿qué hago? Gracias.
Hello
I in trouble with Asus P6T Ws Profesional X58 BIOS version 1107, processor Core I7 975 extreme and 6GB Kingston HyperX KHX2000C9AD3T1K3/6GX, 6 slot 12GB. memory. I did Bios, I think its all right with Windows 7 64 bit. But every day appears the same problem, the computer stops. In a blue screen appears the message:Dumping physical memory to disk. I cannot work, what can I do?
Thanks.
Hello
Thanks.
