Problem with Internet Explorer
SiDiuS
Everytime I open Internet explorer 6.0 I get an error message
"You have tried to access a page that you are not authorized to display and were stopped by the SAS Proxy. First check if the URL you entered was actually the exact one you intended to use. If the URL is correct and this error reoccurs, then please call Customer Care. Give them the URL that you are not authorized to access as well as the page sequence you followed to get to this point. We apologize for any inconvenience this has caused you. "
No matter what url I enter I get the same error message, Mozilla works fine though, mirc, and aim as well. Any ideas as to what the problem is?
mjones73
You have a proxy server set up, go to Tools, Internet Options, Connections, Lan Settings and uncheck all 3 options.
